mattnj
Hi,
Boat is a 2001 Sea Ray 260 with Volvo KAD44
1) Temperature guage shows just under 100deg celcius when up and running at speed, never goes higher and no alarms, is this just a dodgy sea ray guage, where should i look to check it further?
2) I have a mechanical volvo throttle and gear lever on the helm, can this be changed for a the electronic control? Is it as simple as swapping the controls over at the helm or does it not even have the electronic drive selection components?
3) When i turn the engine off, i turn the key to position 0 and the rev counter wanders around at about 2000rpm (even though the engine is idling fine) then when i turn back to the stop position i get a buzzing noise and the engine stops fine. Should i be investigating the tacho reading nonsense when i turn it to zero?
Thanks in advance,
Matthew
Thanks in advance,
Matthew
