Volvo engage gear, d4-300
Rodeo
18 Jul 2012
Clevedon
Last weekend i was out and about, and whilst maneuvering at slow speed, my port engine wasn't engaging forward gear. If i returned the throttle to neutral, then applied forward, it engaged all was fine. I only noticed it a few times.
Starboard engine seemed fine. Any thoughts or recommendations would be most helpful.
Boat is fairly new to us.
aquatom
9 Apr 2007
Mallorca
1) check gear cable adjustment.
2) check excessive play in gear cable.
3) check gear cable moves freely.
4) check for contaminated oil in the drive.
Sishoe
6 Apr 2013
Warsash
www.indigofiresystems.com
Last year mine started doing exactly the same, to a point where a little throttle needed applying to get the drive to engage forward. Turned out the clutch cone was worn, I had them replaced in both drives and all good since. The boat had only done 200hrs !!
wakeup
5 Mar 2002
Cote d'Azur
Sounds like your gear shift actuator (electrical to mechanical) is dying. This is quite common on D4 unfortunately.
You could swap the suspect port actuator with the starboard unit to see if the problem moves.
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
d4 fly by wire no cables:eek:
D4/6 sterndrive does have a manual shift cable from the actuator to the drive, it is this that aquatom is referring to.
Any poor set up adjustment will not allow the cone clutch to engage. If there is a wiring fault in the system this will show up as a fault code. The op isn't saying there is a fault code present so it sounds mechanical rather than electrical.
What make and model of boat is it?
Rodeo
18 Jul 2012
Clevedon
It had a inspection / service before delivery, only got it in december, didn't notice this during sea trial.
It doesn't do it every time. I don't throttle, just back to neutral then back to forward and it will engage.
