jimmy_the_builder
Ooh this sounds like a new problem. Have you put a meter on the ignition switch to prove your 'no power' theory? Eg have you got a separate main breaker for that engine, perhaps on your main dc panel (I'm not familiar with your boat)? If so - have you checked that there is power both sides of that breaker? Does this engine have its own start battery? Have you checked that that battery has charge, and that the connections are good?
In other words, if there's no power, I guess I'd be starting where I know there is no power (ie put a meter on the ignition switch) and then I'd establish where there is power (eg battery) and then work in from both ends with a meter until you find the problem.
