dunedin
As title says, have a Volvo D2 55 which normally runs perfectly (MDI willing!).
Now seem to have lowish water flow, resulting in clouds of white smoke when running engine. Also sounds slightly “rorty” at low revs, but other than smoke sounds fine when running.
This happens
This happened once before around 7 years ago - but that was after been lying in French marina for a few years and saildrive clogged with shellfish- ridding the seacock fixed.
This time boat has just been relaunched and very small amount of shellfish in saildrive was cleared out.
Have checked so far:
- impeller (new Feb) is fine
- take off inlet pipe and decent water flow in through seacock (messy!)
- found slight crack in Vetus filter lid and replaced lid, well sealed, but that isn’t the cure
- no water leaks into engine tray
Also have an anti siphon valve, with dribble pipe, but no water coming out of it
Thoughts as to what else might cause this?
This happens
