tim
Hi,
I've a new boat that has a Volvo 2003. I have to run it at high revs for quite some time for it to heat the domestic water. However, I've been told that diesel engines need to be run under load, otherwise the bores will polish up.
I'm not sure what the problem with polished bores is, but my questions are: -
* Will taking the boat out for a spin 'unpolish' the bores?
* Would loading the alternator constitute sufficient engine load to prevent the polishing?
* Should the engine be able to heat the domestic water on tick-over?
I look forward to your help with this - at the moment the Trouble and Strife isn't happy heating water on the gas cooker after having been persuaded that a good reason for buying the new boat was that the engine would heat the water.
Thanks,
Tim
<hr width=100% size=1>
Thanks,
Tim
