TSB240
I have read the manual but can't find the answer.
Is it possible to bridge the battery and the load negatives for any period of time or will it damage the controller?
I know it is definitely no for the SP connection!
I was hoping to connect our fridge to either the load circuit or battery with a single pole three position on off on toggle without bothering the negative side.
Using a two pole switch is possible but messy from an installation view.
I could disconnect the battery negative from the load circuit by turning the main negative Isolator off.
