Victron MPPT -Any good?
madabouttheboat
20 Jan 2005
UK, but for Covid it's England
Looking at installing a solar setup in time for next season and looking at what to buy, in particular in relation to the charge controller. I want good quality, but I need to keep an eye on cost. I am going to avoid anything that claims to be mppt but is unbranded generic stuff, so am looking at ‘brands’ that I am hoping will do what they say they will. I am currently looking at Victron Mppt bluesolar or smart solar (I haven’t worked out the difference between them yet) controllers as they appear very good value for a well known make.
Am I barking up the wrong tree or are they a decent option. If not, what makes should I be looking at?
Cheers
noelex
2 Jul 2005
The Victron controllers are hard to beat for the needs of most yachts. The Smartsolar models have built in Bluetooth which makes changing charging parameters, updating the firmware and viewing results easy.
You can add a Bluetooth dongle to Bluesolar models, but the total cost is similar and the functionality may be a little less.
Aja
6 Nov 2001
With built in Bluetooth the Victron MPPT controllers work very well and allow you to access it's data and save the last 30 days off line.
As others have mentioned it also allows charging parameters to be altered to suit your charging regime - thanks @PaulRainbow for your help when setting mine up!
Gustywinds
1 Mar 2024
I have a Smartsolar 75/15 but have never used it…
Reason I have it is the guy who did my install asked if I was ever likely to fit solar. I said not very likely but…
It only added something like 100 Euro to the near 15k I was spending so it’s there.
Mostly Victron stuff (batteries, inverter charger and all the monitoring widgets). All nicely made and has been 100% reliable, still getting my head round some of the software options.
I might look at some panels when we get to the Med next year but other priorities are more pressing.
Gixer
29 Nov 2015
I bought a second hand Victron Bluesolar as a cheap price. Feeling very chuffed with myself I tried connecting it to my phones app…
I then realised my mistake and ended up buying a Bluetooth dongle for it. Doh
Rafiki
20 Jul 2009
North Bucks
I bought crap £12 from ebay, after using for one week-end I spent £70 on a Victron Smart Solar. I could then genuinely see if the solar panel was working -- enough said ?
Daverw
2 Nov 2016
Humber
Cheers
Victron every time, also 5 year warranty
Thresher
19 Aug 2002
Tollesbury
Sorry, not quite enough said. What was wrong with the one from ebay? I know my solar panels are working because i have a multimeter and I can test them, they charge my two lead acid batteries totalling 200ah. I have the cheap controller from ebay and often wonder if i am doing something wrong or shortening the life of my batteries by not having a more expensive controller. What does the Victron offer that the ebay controller doesn't?
Daverw
2 Nov 2016
Humber
The eBay one is unlikely to be MPPT and although will work will not be as efficient as the the victron especially in lower sun conditions.
William_H
28 Jul 2003
West Australia
The cheap controller will be pulse width modulated type not MPPT as claimed. (possibly) PWM is in effect a simple connection solar pV panel to battery with the ability to interrupt charge when battery seems fully charged. It may have a charging (tapering) profile but in practice with small panle will almost always be running full power.
MPPT has the ability to transform the incoming voltage to that needed to charge the battery. 12v up to 14+ volts vrom what ever it can gleen from the PV panel. ie low light still gets some charge in to battery. Max light can actually produce more current than panel. The best part however is the ability to get max power (current) from a large 40v panel into a 12v battery. So yes Victron MPPT is good. ol'will
Trident
21 Sep 2012
Somewhere, nowhere
How much solar ? Victron are great as everyone has said but get expensive as you go bigger
Renogy are also excellent and their bigger MPPT (up to 60A and 100A ) are a lot less expensive than Victron and I have fitted lots and lots of these without issue .
noelex
2 Jul 2005
If there is a need for a large controller such as a 60-100 A unit it is worth considering multiple smaller controllers.
The performance is better and the system will have valuable redundancy. The cost depends on the specific size of the solar array, but it can sometimes be less expensive.
