pandos
My new to boat has one of these fitted. It has 3 outputs, 30 amp.
Batteries were arranged as one standard ( wet) LA starter, and one wet LA and one lithium joined to form a house bank. There was an unfitted lithium.
The professional who fitted the charger put a jumper between two of the outputs and connected the combined output to a broken wire, and connected the other output to the house (mixed) bank.
The only way to charge the starter battery was to use the 1 2 both switch.
I have sorted some of the set up.
I took out the blocking diodes and put the two lithium batteries together to be charged via an Orion smart DC to DC charger, from alternator, via the starter battery. (haven't tested this yet, fuel system being worked on)
The mains battery charger is connected to both banks with the jumper removed and is putting current into both.
On Bluetooth the charger just shows one output and seemingly it is not possible to use different charge regimes simultaneously.
As I have a mixed bag of batteries do I need to add a second charger and set one for LA and the other for lithiums, or which setting should I use.
At this stage another 120 for a second charger is better than a ruined battery especially two ruined lithiums, is this the best option..
TIA..
TIA..
