crispyone
I have 2 identical and entirely separate systems, each has 2 x 100W solar panels and a Victron 75/15 MPPT charge controller, connected to 2 x 110AH 12v leisure batteries. I have a voltmeter/ammeter monitoring the cables to the battery, with a shunt in-line in the +ve cable.
Initially everything worked fine - batteries charged to a float voltage of about 14.6V which is what I would expect. However occasionally one or both the systems starts showing a rising voltage, up to about 16.5V, measured at the controller battery connections and also (via a separate voltmeter) at the batteries, but with very low or zero charging current. Once this happens the voltage remains at that high level even in low light.
The Victron agent suggested disconnecting the controller, then reconnecting (battery first, then solar panels). This should reset the controller to charge 12v batteries (not 24V which is an option).
Have done this several times, to no avail.
I have an isolation switch to disconnect the panels from the charger, which I use when there is no solar panel input (dark or covered up). The battery voltage then drops slowly to about 12.6V.
The actual voltages may be inaccurate but the readings are repeatable and consistent - cheapo Chinese digital meters.
The batteries do not appear to be suffering.
Any idea what is going on? Is this a problem?
