VHF mast top antenna mounted upside down
FairweatherDave
28 Sep 2009
Solent
Wandering around the boat yard today past various masts lying down on stands. Noticed a couple of masts with their antennae deliberately mounted upside down. My initia reaction was they must be like that just while they are down, to avoid accidental damage, and they will be remounted normal way up come time to step the mast. But then I thought maybe they were that way to avoid whirly wind instruments, and they are permanently upside down. But wouldn't the mast create a reception blind spot?
Mark-1
22 Sep 2008
My mast is on a rack right now and I've turned it upside down as you describe to keep it out of the way.
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
It might create a reception blind spot but the wary do it over winter to avoid folk damaging the aerial with boots or tyres.
Didnt bother myself but as my new aerial does not actual work as per PBO post, it might have been ill judged
FairweatherDave
28 Sep 2009
Solent
Well my mast will be coming down sometime over the winter and it does look a pretty sensible thing to do while stored. I haven't had a (funtioning) mast mounted antenna for a while, just one of Salty John's finest mounted on the pulpit with a very long cable coiled and ready to install properly. If I can sort the wind instrument at the same time that'll be a bonus.
alan_d
15 Mar 2002
Scotland
Common to do this when the mast is off (if the aerial is not going to be taken away) to reduce its vulnerability to being struck and damaged.
Moodysailor
7 Sep 2020
Same here, used to turn it around when the mast was down to stop anyone walking into it and snapping it off (had one "die" that way)
Daydream believer
6 Oct 2012
Southminster, essex
I fix a batten to the mast & tape the aerial to that. I also fix the windex & wind instrument to it as well.
Then at the base of the mast I stuff a piece of 1.5 inch square batten up inside the mast 2 ft, so it projects 3 feet & then strap the forestay foil to it. It is amazing how may people just let their foil drop over a stool to kink . Some get quite badly damaged.
Bilgediver
6 Jun 2001
Scotland
My mast bracket has a slotted hole so yes everytime the mast comes down the antenna is reversed in the mount to reduce the chance of damage and also prefent tripping passers by.
