laika
Hmm...in defence of those people who *do* do radio checks with someone other than the marina they're starting from (and yes yes, NCI...)...
My VHF seems to be performing very poorly since the last time I actually used it to call anyone other than Brighton marina from Brighton marina (over 18 months ago). The squelch is up quite high. Marinas can hear me when I'm close but a couple of miles away I'm apparently distorted. Also I can only hear occasional coastguard messages and those are often distorted. A problem with my antenna, which has obviously suffered some stress over winter (the close hauled "wings of my hawk vanished over winter)? Fortunately I have a spare mast-head antenna and cable. Switched over. No better. splitter in the AIS? Fed the cable directly into the VHF. No better. The cable which connects the connector at the bottom of the mast to the VHF? I've checked resistance between the conductors (infinite). I got my multimeter out and using a long piece of wire checked the resistance between both ends of each conductor: In both cases rather less twice the resistance of the piece of wire I was using to provide my multimeter with a circuit. I'm not sure what more I can do without buying a long piece of RG85 a couple of connectors and a couple to replace it all, but seeing as coax isn't cheap I'm wondering if it's worth it given the resistance seems low. On the other hand I have minimal RF knowledge.
Ideas?
I'm thinking of heading into weymouth to see if I can find an emergency VHF antenna but ideas on further debugging I could do appreciated (and also ideas on the soundness of my idea that low impedance in wire means there's not a corroded connection issue).
Ideas?
