santavey
please can someone explain the following.
Havings lots of trouble with VHF. Suspected masthead ariel at fault. Replaced with pushpit mounted one. Works OK but with poor range. Also picks up lots of noise that has to be squelched out almost to the point where no signals recieved. Worst on Ch16 especially with engine running. Got fed up. Replaced masthead ariel. Still as bad, worse than pushpit ariel. Replaced lead (RG58) between new masthead ariel and radio using barrel type connector. The spare wire from the new ariel left coiled up under the headlining. Searched for VHF problems on forum. Bought SWR meter. Connected to pushpit ariel. Tested same. Now this is where I really begin to loose it!
Ch M Forward 30 watts, reflected <1, SWR <1
I thought it was limited to 25 watts.
Connected SWR to masthead ariel without using the new internal cable.
Ch M Forward 14 watts, reflected 1.7, SWR 1.4
Repeated test with different radio. Very similar results.
Same test on Ch 77 gave Forward 20 watts, reflected 2.8, SWR 2.2. Why different results on different channels?
Ran test with masthead ariel & new internal cable.
Ch 77 Forward 18 watts, reflected 1, SWR <1
Am I messing with things I really dont understand or is there a simple answer?
Any advice received with thanks.
