VHF/DSC
Micky
27 Sep 2004
UK
Fitted my radio up today, linked in with GPS unit, but how do i test it? I know the radio is ok, but what about testing the GPS.
If it doesn't work, the radio will start beep beep beep BEEP BEEP BEEP BEEEP BEEEP BEEEEEEP to subtly inform you it is not receiving GPS information!
Depends on the radio but mine displays the lat and long. As shipswoofysays. if it cant see the nmea sentences from the gps it will let you know.
Ian
Ah, i guess i need to set it up, not just plug it in.
Will have a crack at it today, trouble is i don't have an operators manuel for the GPS, so it's fiddle with the menu.
Thanks for the feedback, will let you know how i get on.
Does anybody know how many devices can be connected to my one nmea 0183 output from my gps, and what is the best method for connecting them? I need at least 2 at the moment, one for downstairs plotter and one for pilot.
Hi Tim. I would much appreciate any copies of documents regarding a Garmin 48 GPS, coupled to a Cobra VHF/DSC radio.
Tried setting it up again today but failed.
on the Garmin 48 you need to go to the interface page via the menu.
first line is the I/O format - highlight it via rocker, press Enter then rocker to none/NMEA
next line set to NMEA 0183 2.0
neat line go for 4800
The Brown wire is NMEA +ve and you should connect the black ground wire to the NMEA -ve or ground of the radio
I have guessed that the Cobra will be happy with v2.0 and 4800 baud, if it's manual says otherwise you change them in the area above
I will however bet a beer that the above will work........
Thanks Duncan.
I guess this is where i have gone wrong and get NO response, as i have connected the RED to RED and the BLACK to BLACK.
i Will change it over today, BROWN to BLACK and try again. Many thanks....will let you know what happens.
Micky - that's Garmin brown to whatever is the NMEA +ve, or NMEA input on the Cobra radio - I can't find any online support for the Cobra so I can't tell you what colour that will be!
The black from the Garmin is it's unit ground, which you will have connected to -ve battery etc to power the unit. This usually, but not apparantly always, needs to make a direct connection to the NMEA -ve wire of the Cobra radio if it has one.
OK?
Tried to set up the GPS to Radio again today, but still no luck.
I think the units are handshaking OK, because, when i switch the radio off, a message comes up on the GPS as RT?? has failed, i forget what the exact initials were.
