TonyBuckley
My VHF (DSC Standard Horizon GX1700) has had a reducing performance recently.
I have disconnected all the connections and one was very badly corroded due to a leak at the mast. Lots of white and green crud.
I have tried to clean as best as I can with a rag, but need to get some wire wool in there to clean properly.
My question is... Due to transmitting to check the radio, is it going to be buggered due to the power not getting out?
What is the best way of protecting the connections - does winch grease for example allow the signal to flow, or would it block it?
At the moment, lots of WD40 was sprayed to help loosen up the crud.
Hoping to get back to boat this week and sort.
I ask because 'perhaps' the recent storm has caused probs at the mast head although I did notice an issue before this.
What do you think?
What do you think?
