Andrew_Trayfoot
I have a spare patch l
Will double check there is no continuity between the core and shell on the patch lead between the radio and the mast foot.
I have a spare lead which I can try when the mast is back up.
Have you checked the cable from mast base to radio to be sure you have no circuit between centre pin and outer shell on all your connectors?
Most likely causes are corroded cable and badly fitted connectors.
