Gross Tonnage (GT) is a function of the volume of all ship's enclosed spaces (from keel to funnel) measured to the outside of the hull framing.
Tonnage measurements are now governed by an IMO Convention (International Convention on Tonnage Measurement of Ships, 1969 (London-Rules)), which applies to all ships built after July 1982. In accordance with the Convention, the correct term to use now is GT, which is a function of the moulded volume of all enclosed spaces of the ship.
It is calculated by using the formula : GT = K x V, where V = total volume in m³ and K = a figure from 0.22 up to 0.32, depending on the ship’s size (calculated by : K = 0.2 + 0.02 logV), so that, for a ship of 10,000 m³ total volume, the gross tonnage would be 0.28 x 10,000 = 2,800 GT.
Thanks for all the information so far. This is required for the Ship Radio licence application on the Ofcom site. I presume a rough guess of 3 would be OK for this use?
I think 6 or 7 would be nearer the mark, actually. Think of it in terms of how much the boat would weigh if you completely flooded it. As an example, an 85' powerboat might weigh 50 tons (?) but the GT would be around the 200 mark.
My mates boss had a 30-31ft rinker which weighed in around 5.5 tons. I would put yours in around 4 ton.
But, i've just looked on boattest.com and it states 7241 lbs which is 3.29 tons. Bayliners are even lighter than i thought /forums/images/graemlins/grin.gif
Steve Boerema of Viking Yachts (who make luxury sportsfishing boats in the USA) kindly supplied me last year with the info below from the USCG re calculating gross tonnages :
But Deckhouse volume is ignored, since it's volume is less than that of the hull.
Hull Volume = S x K x L x B x D
Where L is Length on deck from bow to stern (excluding pulpits and swim platforms),
B is overall beam at the widest point of the hull (excluding rubbing strakes),
D is total hull depth amidships from hull bottom to weather deck (excluding the depth of the keel and any capping rails).
S is the Shape Factor, and is given as 0.67 for powerboats.
K is the Keel Factor, and is given as 1.0 for all hulls except sailboats.
Net Register Tonnage = M x GRT
where M is the Machinery Factor and is given as 0.8 for vessels NOT designed for sailing, with inboard propulsion machinery.
Actually there are various Gross and Nett Tonnages and ships have more than one. What you quote is purely London Rule - it is not the only one. It is apparently trying to reconcile the different tonnages into one system Still to this day not achieved. Today GRT and NRT are still the figures entered on Ships Certificates - as we see in our work. But you are correct to say they are volume corrected figures and not related to actual tons / tonnes.
I can say this with reasonable feeling of being correct - conisdering that I deal with ships every day of my work.
To the original poster - for Ofcom applications it is not necessary to be exact with GRT for Radio licence (pleasure / private boat) as it's actually an invalid figure. Usual displacement is good enough.
How are lots of guesses from people who don't know the answer (and many of whom clearly don't understand the question) supposed to help this poor chap?
The most helpful answer was the one that someone cut and pasted from Wikipedia -- but I'm sure he could have googled that for himself!
OK, so our old Fairline Targa 28/29 had a GT of about 7 tonnes. It also displaced about 4 tonnes. Neither will be radically different for the Bayliner, I expect (+/-20%).
As it's for OfCom, those figures will be good enough.
Problem is that GRT is irrelevant for pleasure craft. It was originally used to determine port and light dues for commercial ships - and still is. However pleasure craft do not pay light dues and mooring fees (and harbour dues where levied) are usually based on length or in some cases area (L*B).
It is also irrelevant for a VHF licence as there is no legal requirement to fit one.
One can only assume it is laziness on the part of OFCOM to continue asking for it. Would they refuse a licence if it was not declared or a guess used?
[/ QUOTE ] It is one of the questions on the application form which has to be answered. I have no idea what the gross tonnage would be for my boat so I tried to leave the box blank but I could not proceed with the application so I put in the displacement. It was that that prompted me to seek the clarification from OFCOM that I mentioned earlier. I subsequently amended the licence details to a more realistic figure.
The justification for asking for this info is I believe, not laziness on the part of OFCOM, but that it is something they have to provide for SAR purposes, irrelevant though it may seem.
If you look at your details in the ITU Mars database you will see the registered tonnage is there at least if you have licensed under the new scheme of things.
A good idea to check your details there anyway! You might find someone else has your call sign, or you might find, like me that you are not listed at all. /forums/images/graemlins/mad.gif
Just checked and my details, Name Call sign MMSI all correct but not GRT so I assume I registered (years ago) before it was a requirement, which is perhaps why I am displaying my ignorance! Anyway my boat is on the Part 1 so I have the Blue Book with all the detailed tonnage measurements so if required, I would be able to fill it in "accurately" unlike most people who will have to "guess".
I would hope you are not including my post in the "guesses" category - or did you mis-read my post ?
As I said there : I work with this rubbish every day and GRT / NRT is not valid for a plaesure boat usually - and Displacement is more commonly put on the form, as it's only valid number usually given by builders etc.
As to why Ofcom needs GRT ? It's a hang over from Ships - because it irks some boaters to think that there are others out there as well as pleasure boats !!
