VDO Tachometer hourmeter repair
Dino
27 Apr 2009
Ireland
Hi all,
My Broom has a pair of VDO Tachometers with analog hourmeters. They are not the digital LCD screens that regularly fail.
They hourmeters on both have stopped working. Someone mentioned that the plastic gears can sometimes fail.
Has anyone repaired one of these?
Any advice or links to information would be very much appreciated.
Dino
27 Apr 2009
Ireland
On closer inspection it looks like I’m missing a gear wheel between the worm gear and the white gear cog.
billskip
6 Sep 2001
Certainly looks like a missing gear..do you know any clock repair people?
Does the motor work?
Dino
27 Apr 2009
Ireland
Thanks for your replies.
Bran, that’s a very tidy job. I’m going to try to repair the mechanical hourmeters if possible.
I had previously been in touch with this company and this gear looks like it might be the one I need. There was nothing left of the old gear so I’ll open the second gauge to see if there’s anything left.
https://partworks.de/partworks/en/8...rine-hour-meter-speedometer-boat-engine-hours
petem
16 May 2001
Cotswolds / Altea
www.fairlineownersclub.com
Alicatt
6 Nov 2017
The hour meter works on my Broom with either engine running, just the one hour meter shared by both engines.
It's the speed log that is not working, the cable drive spins up the gauge but the sender under the keel does not move, was having a look at it today.
Dino
27 Apr 2009
Ireland
So I took the chance and ordered the two gears from Germany. The gauges were a bit tricky to disassemble but I took my time and worked it out. The needle was the hardest part. It wouldn’t pull off so I twisted it and that freed it up. I kept turning and applied a bit of a pull and it came away. To fit the new gear, I had to split the frame and then remove the two other gears. The larger one has a shaft that slides out and the smaller one has a tiny brass spring clip. I initially reassembled it wrong but then worked it out.
I got it all back together and the second unit only took 10 minutes.
I polished the lenses with some Meguires PlastX polish and a soft foam pad I had for restoring headlights. They came up really well.
I tested them last night and they are working perfect.
