Varnishing
tyce
6 Jan 2004
cumbria
I am a bit of a numpty at varnishing but i want to do a fair bit this winter so its time to learn.
I have brought the saloon steps home to varnish, the varnish has worn back to the wood on the steps and where it has worn through to the wood it has slightly bleached the wood.
The remaining varnish is not damaged or flaky so do i need to strip the whole lot back to bare wood or should i just sand and revarnish.
Tranona
10 Nov 2007
Your choice depending on how much effort you want to put in and the final standard you want. If you are just overcoating ensure that your new varnish is compatible with the existing. Generally varnish is not a good finish for high wear locations such as steps so you might consider using a different surface there and just varnish the frame.
VicS
13 Jul 2002
When you sand be sure to sand along the grain... sanding across the grain will produce scratches that will be visible.
As MrT says ensure what you apply is compatible with what is underneath. Don't use a two pack on top of a single pack!
Read the product data sheet before you start
Be sure to get rid of all sanding dust. A vacuum cleaner is not good enough to get rid of it all. Wipe down also with lint free rag and thinners or preferably a "Tack rag" ( you can wash a sealed surface with water but perhaps not such a good idea on bare wood)
Aim for 5 or 6 coats, rubdown lightly as necessary between coats but remember sanding is removing varnish you have already applied.
Be sure to use a clean brush .. no bits of paint in it. Apply enough to properly cover the surface and just flow but not enough to run. ( its always the final coat that runs ... Sods law.) Dont go back over it after it has started to dry. Good lighting where you are working is vital.
Find a dust free place to work. No children stirring up dust .. no dog or cat to shed hairs Definitely no where SWMBO will go near .. wet varnish is a magnet to them.
Consider protecting the finished item with some no slip strips on the steps. Or as Mr T suggests something different altogether on the treads
tyce
6 Jan 2004
cumbria
Thankyou all for excellent and detailed advice, very much appreciated especially vic for taking the time to give a very detailed reply.
VicS
13 Jul 2002
Locker tops and wash boards behind me waiting for their annual coat of varnish!
( used a brush that had some dust in it last year ... wont make that mistake again)
Captain Coochie
19 Apr 2003
London
Strip it back to wood
Then add pure turps to the paint and varnish . Denib between coats with wet and dry and wipe of any dust with Meths , turps etc .
Grajan
24 Jun 2004
N. Ayrshire
Don't think they produce Universal Clear Primer any more, it was a great product if you new what it was !! a TWO pack varnish. UCP used moisture as its curing agent hence the problem re-opening the can, those who have used this product will know what I am talking about.
The secret of achieving a special varnish finish is to rub down with a medium grit paper dust off and apply say three coats then de nib, this allows fibres in the timber to act as "anchors" for the varnish - apply another couple of coats, allow varnish to harden then flat back with wet & dry 400 /600 used wet - clean off with thinners apply final coat(s) using tack rags prior to applying the varnish and as VicS says a dust free atmosphere and dont wear a wooly jumper!
A good brush does make a difference and wash out between coats
we used to always suspend our brushes on a 4" nail in a tin of thinners by drilling a hole through the shank of the brush this keeps the bristles off the bottom of the thinners tin where all the "gritty" bits gather.
VicS
13 Jul 2002
It does seem not to be available in the Uk. Boatpaint.co.uk say is is discontinued
International offer different products in different counties.
In the ROI they now offer a two pack fast dry wood sealer. In the USA they offer a single pack wood sealer.
In Australia a fast cure two pack primer
Same or similar product different names maybe in some cases.
johnalison
14 Feb 2007
Essex
I don't think the actual product used is as important as how, so it would be best to follow the instructions that the experts above have given.
If the loss of varnish is due to wear on the steps, consider putting a non-slip band or brass strip on the area that takes wear.
stav
7 Aug 2002
Jersey
Why varnish where it will get worn away? I would just do the sides. When varnishing (or painting) I just keep the brush in a bottle with linseed oil in and give it a good wipe before using.
For floors I use Durasatin varnish and seems to hold up quite well.
KINGFISHER 8
21 Mar 2007
South of France.
........... and don't forget that varnished steps will be slippery (lethal) when wet ... I've got stick on Trakmark on mine .... good stuff, comes in different sized pads and sticks like sh*t to a blanket.
grumpygit
29 Jul 2007
Sailing the Aegean
Following this topic with interest, I'm probably in the same position as the OP.
Has anyone tried Jenny brushes for varnishing and if so to what success please.
In places that get full UV ( Med sun) I'm leaning towards teak oil instead of varnish. I would love to revarnish because of colours that are drawn out of the teak. It's the stripping back every time.
Scotty_Tradewind
31 Oct 2005
Me: South Oxfordshire. Boat, Galicia NW Spain
The OP is varnishing his internal steps. Definatly add some non-slip of some type to the varnish on the steps, then wash off when the varnish has gone off.
One owner said that he recently did this by sprinkling sugar onto the wet varnish from a sieve. I've just had some non slip areas on my GRP decks done in epoxy and fine sand/shell grit which gave a surprisingly fine non slip result. Not too damaging to knees or clothing I hope.
Outside varnishing is a lottery - how much time have you got each year to keep up with it? And is it better to leave natural and grey?
It definitly helps maintain good quality varnish to cover from sun and frost.
Poignard
23 Jul 2005
South London
Me too. You can get a glass-like finish fairly easily but they're not a substitute for good technique.
Yes, you do need a brush to work varnish into tight corners and seams.
I did also buy some foam rollers but I haven't tried them out yet. Probably a mistaken purchase because I don't have any areas of varnish large enough to justify their use.
