syvictoria
Hi! Sorry in advance for the lengthy post...
I won't beat about the bush - this is one of those annoying I don't know how much to ask for my item, but here's what I have available... hint, hint, nudge. nudge... posts!
Sorry, but needs must - I promise I won't do it again!
Anyway, here goes... We will soon be removing a running 2GM20 engine and gearbox, and, as per the title, I'm not really sure what it's secondhand value is. Apart from having ran it briefly a couple of times, I unfortunately know nothing more about the engine than is recorded in the survey back in Sept. 2009:
"Yanmar, Model 2GM20, Serial No. 08264, 2-cylinder naturally aspirated direct cooled 4-stroke diesel engine close-coupled to a Yanmar oil-operated reversing-reduction gearbox, flexibly-mounted on grp moulded...
Engine sump and gearbox lubricating-operating oils checked by respective dipsticks, found to be clean, free of visible contamination and filled to the correct levels.
Engine examined externally as installed, turned over manually on and off full compression, with no unwarranted movement or slackness felt affecting little end bearings, big end bearings and main bearings, during each rotation.
The gearbox was not engaged in either the ahead or astern movement as the neutral button in the single lever control was stuck in (now fixed!).
1. When turning the engine over manually on full compression, compression felt low.
Engine was briefly started using self-start system, taking some time to start, probably due to low compression, run for approximately 30 seconds only.
2. External surfaces of engine lightly corroded and rusted through paint coatings, especially the bed plates of flexible mounts and the coupling between the gearbox and the propeller shaft.
3. Alternator-water pump drive belt slack."
The surveyor then went on to recommend that the engine be removed and overhauled. However, as we plan to own the boat for a long time, and we will be living aboard and cruising full time, we've taken the decision to bite the bullet and replace the engine rather than overhaul it. Unfortunately the engine has no engine hours meter, and as the previous owner had passed away, we don't really know anything else about it. The boat was (and currently still is) ashore when we bought her. We assume it's the same age as the boat (built 1987). It's currently still in the boat, and should be removed April/May time, unless someone is willing to pay for the crane in the meantime (and assuming that the yard can get the crane to the boat, which would be difficult at the moment).
Once again, I apologise for the blatant bending of forum rules, and I will understand if the mods want to delete this post
Is anyone able to give me some idea of what sort of asking price I should be looking at or, even better, is anyone looking for a lump to overhaul!!!
(BTW: I hate eBay, so please, no suggestions about putting it on there - that will be my last resort.)
TIA!
TIA!
