Whitelighter
Watching the SQ58 displacement thread it reminded me of a problem I have with Seralia.
The boat has a V drive set up, so engines mounted 'backwards' with the shaft returned through a reversing box.
When running at displacement speed after a couple of hours I get a overheat alarm (usually on port first but can happen on either) indicating the reservsing box is getting hot. The water cooling for the V drive is passive force - a pick up in the hull which I guess requires speed for sufficient pressure to keep the flow going. Ive checked and cleared the filters and they seem fine, but I guess after 22 years its possible there may be some build up in the pipe? Now it may be that these were never designed to facilitate slow speed running but I'm surprised if the cant cope with pootling.
Any suggestions how to clean the pipes? and with what. Without a pump how do I force the cleaner through.
Also, is it reasonable for the boxes to need that much cooling or should I be looking at another issue. Popping the boat up onto the plane for 20 minutes cures the alarm for another couple of hours but that's going to be a pain on a night passage.
