An interesting point emerged from the "Engine on/off" thread below which was about whether to run on one engine in a twin engined boat during prolonged spells at slow speeds.
As conventional wisdom says that running a high speed diesel at slow speeds for lengthy periods is bad for them - glazed bores, turbos never used, etc, I just wonder if people who have done long trips through European canals with fast boats have had experience of problems with engines after a bit, especially when returning to the sea. Are there words of wisdom available?
In MBM or MBY, can't remember which, I have followed the trips of Darius, a Monnraker, which seems to have covered more European waterways than most. As I recall, these boats were fitted with Perkins T6.354's which I think were turbo charged (I could be wrong here). As these are pretty ancient now, it can't have done them too much harm!
The only canal work I have ever done is basically the Crinan which can be negotiated in a day if you are in a hurry but more likely a leisurely two days with an overnight sampling the delights of one of the restuarants along the way (especially a the Crinan Hotel!). My boat ran OK through it but when I hit the sea again, opening the throttles laid a very embarrassing smoke screen worthy of a Destroyer flotilla!.
Nick
Nick
