Spirit (of Glenans)
I know it's a little adrift of the OP's topic, but almost the first item on a Powerboat Course is that your painter should not be long enough to reach the prop.
Agree with you in that but if the painter on a small dinghy is only slightly less than the length of the dinghy it won't be much use for mooring the thing.I know it's a little adrift of the OP's topic, but almost the first item on a Powerboat Course is that your painter should not be long enough to reach the prop.
Oh dear, I cringe when people like Thinwater suggest you grind brass on a bench grinder, It is both stupid and possibly suicidal. You must NEVER use non ferrous materials (eg brass, copper. aluminium etc) on a bench grinder for your own safety. Jim
Do please enlighten us to the damagers.
Good grief ..... I cannot think of any metal or any plastic which I have not ground on my bench grinder over the last 40 years.
Except gold .... I can't remember grinding any gold.
Richard
When I worked(now retired) as a fitter/turner chargehand the rule in the workshop was anyone caught using a bench grinder to grind non ferrous material they were liable to instant dismissal.
And by the way mild steel has a carbon content. Jim
I would stick with a shear pin that is what they are made for a nail isn't.
I'm going to make a new rabbit hutch when I get home for Flopsy. I've got lots of redundant shear pins from long dead outboards. Do you think I could use up the old shear pins to nail the hutch together?![]()
One square inch?
A one square inch piece of steel as a sheer pin for a 3.5 Mercury? hohum!
You don't understand this stress and strain thing, do you? Nobody suggested a one inch square shear pin. Go back and read the post again, slowly.
