PabloPicasso
Thank you.I'm sure this is why boiling water works too. I was surprised by how well it works and equally by the claims in this thread that it does't!
I am sure there are circumstances in which boiling water might work but I have severe reservations about the method here. The track is a thick walled aluminium tube 2 - 3 cm square. The bolts holding it down are about 4 - 5 cm long, pass through a considerable thickness of aluminium, then through GRP about 4 - 5 mm thick, then into a threaded aluminium plate.Thank you.![]()
That was my thought - everyone seems to be assuming a lot of corrosion, but I don't see any reason to assume it. If the s/s / aluminium interface on the head isn't corroded I would have real hope that the seal under it is also intact. A bit of heat to soften the sealant should do the trick.When I removed the track on my Sadler, very similar or exactly the same as the OP's, the bolts came out easily.
Can the OP get to the backing plate?Of course it’s not just the s/s screw contact with aluminium of the track itself but with the plate buried in the glass fibre which is a much longer journey for penetrating fluid/boiling water/freezing shock spray. Also wondered if the fact they (presumably) used machine screws with finer pitch than a bolt makes area of converted AI bigger and harder to shift?
Cutting through the machine screws between the bottom of the track and the deck not straightforward as angle grinder won’t fit - maybe Dremel will work
Ok ok, I'll let the bkiling watee go. If the OP wants to direct heat what about a soldering iron applied to the heads of the machine screws?....
Haven’t been able to get to the boat much but this afternoon after spraying with cold shock fluid the impact driver (manual £17 from machine mart) got one screw started - didn’t have time for more but now more hopeful.
There's a reason powered impact drivers have become popular.Haven’t been able to get to the boat much but this afternoon after spraying with cold shock fluid the impact driver (manual £17 from machine mart) got one screw started - didn’t have time for more but now more hopeful.
You could have boiled a lot of kettles for £17. Now we will never know....Result! All 8 machine screws removed unbroken and track removed. Irony is that unsuccessful tour of Screwfix, Toolstation etc for a 10mm slotted bit for my power drill driver led me to Machine Mart who offered a £17 impact driver, which actually worked in tandem with stuff that freezes the nut to break the contact - maybe impact driver would work on its own, who knows?
