Upgrading the dinghy to electric...
newtothis
28 May 2012
This should do for getting out to the mooring.
The Swedish-made Candela C-7 electric speedboat mimics airplanes to fly above the water, reducing friction and finally enabling long electric range at sea. Today, the first C-7 arrives in New York.
Making fast electric boats is inherently difficult. To overcome the water friction, conventional hulls need huge batteries to attain higher speeds. Even then, conventional electric boats have considerably shorter range than fossil fuel competitors.
Taking inspiration from fighter jets and drones, the Swedish-made Candela C-7 is the world’s first electric boat with the elusive combination of long range and high speed.
The 6-passenger daycruiser flies above the waves at a speed of 30 knots, using very little power from its 40 kWh battery.
The secret behind its efficiency is a decade-old invention, the hydrofoil, coupled to modern computers, software and sensors.
At speeds above 14 knots, two underwater wings provide enough lift to raise the hull above the water, reducing water friction by 80%.
This allows for a range of 50 nautical miles at 22 knots, which is 3 times longer than any other fast electric boat on the market.
But Candela’s hydrofoil tech has other benefits, too.
While flying, the C-7 is stabilized by a computer similar to the Flight controllers used in modern fighter jets. The hydrofoils are automatically adjusted 100 times per second to ensure stability in flight.
The result is an artificially smooth and completely silent drive, even in winds and waves.
Thanks to the efficiency of the foils and the streamlined electric propulsion unit, the cost of operating a C-7 is 95% lower than driving a conventional fossil fuel boat. At a cruising speed of 20 knots, the energy usage per nautical mile is just 0,8 kWh - the equivalent of 0,2 liter of gasoline.
To save weight, both hull and deck are made from carbon fiber and weigh only 240 kg. At a total weight of 1 350 kg, the C-7 is thirty percent lighter than a conventional fiberglass boat. Design and manufacturing take place in Stockholm, Sweden, where Candela's 50-strong team of engineers and technicians also develop the hydrofoiling ferry P-30 for the city of Stockholm.
Greenheart
29 Dec 2010
Yup, here's a very recent photo.
penfold
25 Aug 2003
On the Clyde
Given the idea is at least 100 years old and most of the heavy lifting in hydrofoil research was done in the 1950s and 60s the statement is clearly nonsense.
newtothis
28 May 2012
To be fair, the press release comes from a Swedish company and the subtleties of English pluralisation may have escaped them. I had a German girlfriend who could never understand why the English would get their "hair" cut, when surely you would get all your "hairs" cut.
If you change that sentence to "decades-old invention", it make more sense.
