AntarcticPilot
I'm thinking of installing a small mains operated water heater; the kind with a small tank (around 5-10 litres, like this https://www.screwfix.com/p/flomasta-undersink-electric-water-heater-2kw-10ltr/997ym?ref=SFAppShare), operating on about 2kW. I have a spare MCB on my mains consumer unit, and would use that to power it.
There is an existing calorifier, which works fine but which only provides hot water after the engine has run long enough to get up to temperature - which is a long time; the Volvo Penta 2003 warms up very slowly! The calorifier is difficult of access, being at the after end of the cockpit locker, and does not have any facility for fitting an immersion heater. Replacing it would be a difficult and arduous job.
What I have in mind is to install a water heater on the return line from the calorifier. This would provide hot water in both the heads and the kitchen sinks. If the water is hot from the calorifier, the thermostat of the water heater will keep the power off. I'd put the water heater in the heads compartment, where I think access to the pipework is feasible.
This may be a totally bonkers idea! But having hot water reliably available while in a marina would make a big difference to my comfort.
Any thoughts or suggestions would be welcome!
I should say that cost is a factor, so using a diesel water heater is not going to happen. And changing the existing calorifier for one with an immersion heater would be a difficult job.
