UPDATE tV aERIAL
trog
12 Jan 2005
well get the glomextv v9125one, today and went to boat.
Was disappointed in the rece[ption on tv, no real difference to indoor tv aerial.
Was wondering if i might be best mounting it on a pole? for extra height.
My daughter even said to me, mam i think the aerial might be broken /forums/images/graemlins/blush.gif
So not really further forward /forums/images/graemlins/confused.gif
sarabande
6 May 2005
Have you tested the aerial at a different place to see if it is producing a signal there ? Is the aerial directional ? Can it "see" the nearest TV broadcasting aerial when on board ?
trog
12 Jan 2005
got told is was omini directional, might try it other side.
It was postioned on top of radar arch but took it down stairs and seemed to get a better reception at bow of berth
I just dont understand aerials at all.
ian38_39
18 Jul 2006
Birmingham
Try turning it on its side, apparently TV signals in the UK are broadcast in either vertical or horizontal configeration dependant on where you are, flying saucers are only any good for one of them don't know which though.
We have a status omndirectional on the Norfolk broads and guess what.
SpiderDiver
27 Aug 2004
South Coast
It's really all about height and making sure not affected by surroundings which will give echoes and affect signal strength.
You can't beat putting it up on a pole on radar arch really. You may find a picture elsewhere but may not be a consistent signal.
I have a Triax UFO and seem to get a picture in situations where lesser aerials fail miserably. Also make sure coax cable connections are Ok to aerial - maybe just the cable picking up a signal! With UFO red light lets you know connections are OK and there is power to aerial.
Greg2
24 Jun 2002
We have one on current boat and had one on the last boat. Both flippin' useless - would never buy one. Sorry, that's not very helpful seeing as you just have but I didn't see your earlier post.
trog
12 Jan 2005
What would you recommend instead? Going back to boat tomorrow to have a mess round with it.
Or should i just come to point that realsie not going to get a good reception in marina.
Nickcf
13 Apr 2004
Kent
One of the problems with these aerials is that they receive from all directions and hence the interference! Have you tried a freeview box? Freeview boxes can eliminate all co-channel interference and hence you may get a good signal.
I've found that (where there is a freeview signal) my glomex aerial often won't get any analogue signal that can be viewed but will receive almost perfect digital freeview.
The only other solution is to use a small satellite dish and an old sky box, which so long as you have line of sight to the satellite will give excellent results when moored on a pontoon.
Greg2
24 Jun 2002
As nickcf says, we will probably go to a sattelite dish. Friends had one and alhtoughn they had to set it up at each prot of call it didn't take long and the picture was perfect
PhilipF
1 May 2005
Bradford-on-Avon.
I also would go for a Satellite outfit -certainly in preference to terrestrial.
Problem: How the heck can you hold the dish steady even on the pontoon? Yes; easy on a canal boat. the water is flat and calm. But one hell of a job in any 'sea' marina - I've tried it!
Nickcf
13 Apr 2004
Kent
I use a Multimo dish which is small but has better gain that a standrad offset dish. Bit pricey, but it does seem to work very well even with significant boat movement in unlocked marinas. I do keep the mooring lines fairly tight to stop excessive swing but without causing any damage to boat or fenders.
