Billba
Marinas usually do day rates for visitors which shouldn't break the bank. Also can you spin the seacock through 360 with the handle in the off position? Another way to stop the skin filling twisting off is to insert something that will contact the inner moulded lugs. I used a chisel gripped with a mole wrench. Could someone reach under from the dinghy and reach the skin fitting? If it was set up before hand you could lash the mole wrench to a suitable extension to save continuous immersion. Let me know the Skin fitting size and I can tell you the ID.
