mattonthesea
I can set these but, until I've got my head around it I'm using one of the two genetic settings. Bizarrely for LifePo4 they still have a float period! Of Grid Garage points out that this is wasted uncharge time.Can you set bulk, absorption and float on the B2B or doesn't just have a generic lithium setting?
Ditto the MPPT?
Monitoring SOC without a smart shunt may be problematic. Inbuilt BMS are notorious for inaccurate readings. You may find each battery gives you a significantly different value of SOC
The B2B displays battery and input (solar, alternator, shore) voltage but by LEDs on a scale - not too easy to read.
I'm also about to connect up the battery monitor
