Tim, mine are fitted under the berths in the main saloon. the starboard one supplies the galley pump and the port one the tap in the heads compartment, both are independent and are filled from seperate deck fillers.
Same here.
2 x 100 litre bladders, one under port & starbd saloon bunks, each with separate fillers.
I've connected mine under the sink with a changeover tee so we can use either tank at the galley. This prevents cross syphoning and means you can isolate one tank if it goes manky, which they do periodically.
Dan
Tim,
I have a 100ltr flexible bag/tank under the starboard main saloon berth. It is filled from a deck filler on the starboard side and the pipe for it runs down behind the door of the heads and through the bulkhead so it is hidden. It supplys the galley sink with a "pump" style tap, The heads sink is also supplied from it by a small electric pump. Cheers Ming
