Two stroke outboards
VicS
13 Jul 2002
In theory, Yes 2 Seagulls and an Evinrude, although one of the Seagulls has not actually be used for a good while and neither of the others since pre-pandemic days.
ST840
22 Jun 2014
Southampton
Supposedly only commercial businesses can purchase 2 strokes. But I managed to get a Tohatsu 5hp just last month with no issue.
Blueboatman
10 Jul 2005
Has anyone still got a two stroke outboard motor that they still use?
Includes Seagull engines.
I think my projected 2litres a year of fuel burn is less than the energy required to fuel the servers that are used to empower the Anti brigade for a year .. just noting , like?
ctva
8 Apr 2007
I have two Malta’s which will make one good one soon (around to it project :rolleyes: ) and a good Yam 8hp which I really like but don’t use very often. I would sell if I ever get around to it due to the limited use I make of it.
DAKA
7 Jan 2005
Nomadic
I still use Tohatsu 9.8 HP. its only 27 kg which is about the same weight as 4hp four stroke with full integral tank.
I dropped it in while at anchor 2-3 years ago
kept held of it until my ears popped with the water pressure so 8-10 m ?
I had a rope attached and hauled it out.
rinsed it off with the deck shower
i Drained the float chamber ( manufactures had fitted a grub screw ready)
took both plugs out, pulled the starter several times with the plugs out
left it while we had lunch , put the plugs in and it started after 4/5 pulls
been as good as gold ever since, I thought it might go rusty over winter but started first time after another winter laid up .
i don’t use it much and believe environment better served by me retaining the old one saving all the pollution from manufacturing a new one
Rappey
13 Dec 2019
2 stroke all the way for dingys due to their lightness. 4 stroke for the larger due to economy and superb starting with injection
fushion julz
8 Mar 2021
I have an Evinrude 4hp from 1985... Reliable, light, cheap and surprisingly good on fuel.
Light enough to carry in one hand and to clamp to the sides of the cockpit coaming when I need a tender on board.
Used on a 2.5m Waveline inflatable and a fibreglass dinghy/tender.
Dino
27 Apr 2009
Ireland
I also have a Tohatsu 9.8hp on a 2.9m Aluminium hull rib. Great engine and starts first time, every time. I’m tempted to upgrade to a used Yamaha 15hp 2 Stroke as the 9.8hp won’t plane with two large people onboard. Both models are getting scarce.
BruceK
8 Feb 2015
Conwy
15hp Johnson / Evinrude. ~2006. The last of their stock before they discontinued with small engines.
