EssexPrincess
My Princess 430 has only been used for river use at low speed for two years. Took her out but the Port engine would not reach above 1300 rpm with resulting black smoke and excess fuel deposits around the exhaust. I suspect engine is clogged with carbon deposits restricting the turbo from spinning.
Have been advised it maybe freed by removing the airbox and reaching into the turbo to check freedom of movement, if restricted to use an oven cleaner spray over the blade turbine to soften any deposits, then to rinse system with water to cleanse.
Has any one carried out this process with good results, what technique was used? Is Oven cleaner the best solvent to use or are there better alternatives? Am a bit concerned whether this may cause an issue with shaft bearings. If unsuccessful then I guess its removal and a service. Engine has only run 1000 hours so wear should not be the problem.
Everything appears to be normal operation uo to this speed.
Your advice would be appreciated.
