pessimist
I would like to replace the TV on the boat. I believe it would be more efficient to step up the boat's 12v supply than to use the inverter. Can anyone point me in the direction of a make with an external transformer?
You can't use a "transformer" with a DC supply; it has to be an inverter (or rotary!). So I don't understand the question...I would like to replace the TV on the boat. I believe it would be more efficient to step up the boat's 12v supply than to use the inverter. Can anyone point me in the direction of a make with an external transformer?
I may be wrong here, but some TVs are plugged into a 240v socket but the plug itself steps the voltage down to 12 volts, i think he wants to know the brands of TVs that run on 12volt (so he can connect one direct to his batteries by simply chopping the plug off, i have a router that plugs into the mains because it uses a step down plug, but i could chop it off and connect to a battery if we had a powercut.because the router is 12 volts.
i think that's what he means![]()
I'm talking about a 240v TV which would normally be plugged into the inverter. I believe that most then 'transform' the 240v AC to a 12-19v DC supply. I would like to replace this with a 12v step upYou can't use a "transformer" with a DC supply; it has to be an inverter (or rotary!). So I don't understand the question...
I should have guessed...I may be wrong here, but some TVs are plugged into a 240v socket but the plug itself steps the voltage down to 12 volts, i think he wants to know the brands of TVs that run on 12volt (so he can connect one direct to his batteries by simply chopping the plug off, i have a router that plugs into the mains because it uses a step down plug, but i could chop it off and connect to a battery if we had a power-cut because the router is 12 volts.
If you do go down the monitor route - make sure you check it has speakers, many of the 12V ones don’t, read the specs don’t just look at the side Some use the same moulding for different models - don’t ask how I learned this.Also worth considering a smart PC monitor (who watches actually terrestrial tv nowadays?) or a USB C powered screen that will plug direct into an iPad or laptop.
Not sure I want a TV getting in the way of my main sheet plus the glare from the sun would make it devilishly hard to see anythingCo-incidentally I received a catalogue from cpc.co.uk which mentions "12V Traveller TVs". So you could mount one on your gypsy (ho, ho)...
