pondfish
Hi all do anybody know at what rpm the turbo kicks in on the above engine
Ok thanks let me put it another way have any body got an Antares 760 with a nanni 200hp if so what do you find is the boat/engine sweet spot getting best boost from turbo but not drinking the fuelI do not buy any of this............
Here we go again 'Propellers move boats engines merely turn them' responding to the load placed upon them this is basic stuff.
The manufacturers data sheet can ONLY give one boost number which is at 100% load and rated engine speed.
Your boost curve follows a specific vessels propeller demand curve, you will be getting boost albeit low levels from just above idle it does not 'kick in'.
The power surge being felt is engine passing peak torque and boost levels will be rising more steeply due to shape of prop demand curve, the real one not the calculated one off the manufacturers spec sheet.
Your engine is a light duty automotive engine
Im curious about the meaning of an LDA motor. Is this term used on motors that have reduced longevity compared to say industrial CATs etc?
I believe the Nanni diesel in question is based on a Toyota automotive base in which case some Land Cruisers have over 250k miles on the clock having experienced varying RPMs and loads throughout their lives which I would have assumed being more detrimental to longevity than say a marine motor sat at mainly low'ish cruising RPMs.
I guess what Im trying to ask, Latestarter, is your expert opinion on wheather this term LDA means they wont last as long as say Omega2's mid range engine (although I'd admit I have no idea what his engine is)
Appreciate your help.
