DavidJ
Just go for plan BThe manifold is not threaded. The stud slides up and down through the flange but the nut is stuck on the stud. I So now it's like a bolt, hence plan B, if that makes sense.
ie Treat it like a bolt. You wouldn’t think twice about using a bolt for the second time so don’t risk adding further problems by going for the “ perfect” solution which actually gains you nothing.
I assume the stud will come out of the turbo without fuss
Thanks to Mr Googler for the pic which has brought clarity to the problem
