bowler
Where are you based
Northern Ireland.
Found a local place that will take a look. I need it quick in case we get t he green light!
D
Where are you based
I can't see the point of having them rebuilt just to save 30% of the cost of a new one. In this case, I'd give it a clean, refit it and budget for a new one in a few years time.
Even if not new why wouldn’t you do such a simple thing as priming. Also suggest doing an engine oil change at the same time so you have nice fresh stuff going through. I didn’t run the with starter motor only because on my KAD43 it’s not obvious (to me) how to turn off the stop solenoid.It's not new. However, I found a local turbo place that is familiar with this model and I am going to let them take a look at it for possible refurb, so maybe it'll become as new!
All depends on time and cost - as usual... Figure I may as well while it's off and the boat isn't going anywhere.
The manual says to leave bottom oil line off and run engine with starter motor only with stop solenoid off. Did you go that far or just fill with the syringe?
D
Also for interest I replaced mine after 15 years of corrosion, it only has 400 hrs on the clock.
Also I went new after a few horror stories on here of some refurbs blowing
Oh yes!any record of increased boost / speed with the new one ?
It’s not your egt that damages the Borg warner units like this it’s the fact that on a sterndrive boat the waterline is up the exhaust pipe about 2 or 3 inches away from these parts , the casing just suffers from pure corrosion and nothing else .The old elevated EGTs leading to exhaust turbo tip burn out .
Overloading , bottom fouling , stern gear mis hygiene .......you know the rest .
Another VP turbo thread .
Shaft drive versions don’t suffer as quick as the have 6ft or more of rubber hose pipe to keep it away from salt water levels .
When taken for repair the whole exhaust housing is shot blasted to give an indicaction of the severity of corrosion usually around 3 to 4 mm dis from the housing leaving a big gap around the fan .
ive seen some really crude attempts to re manufacture the housing by boring out and fitting a sleeve , the last one I took to my local repairer absolutely pissed themselves with the repair and just fitted a new housing and fan m this company even trimmed down the fan diameter to fit the sleeve they fitted , no wonder the boat didn’t perform .
Case of boat with a VP 60C. 255HP
A turbo was removed and a turbo refitted , it might have been a new / refurbed or the original unit. Only the skipper knows.
First trip out. Fine while at tickover but a very short time after going into a fast cruise the something thing got red hot and caught fire.
By the time the skipper realised something was wrong, it was too late.
4 new pistons and liners, all new bearings and complete rebuild of cylinder heads and valves.
Engine had to lifted to release con rods etc. A real pig of job.
All down to a faulty turbo and/or installation.
100 boats on our moorings of all flavours .If it going to happen, its either already happenend, about to happen in the near future or has happened recently and is bring fixed as you watch..Your sunny and cheerful disposition never fails to bring a smile to my face??
Just be careful, we are getting some Chinese copies coming available, must be in a Borg Warner box from reputable dealer .
Not bad at that price. I thought it would be over a grand? Tempting...
Aslo be careful you do not have the same engine as Mr Googler and you will need to check your part numbers match. I suspect your turbo is different as the kads have a smaller turbo with their supercharger design. I think your turbo is bigger.
