superheat6k
My boat has stainless trim tabs which are isolated from the main bonding circuit. Since purchase I have replaced the dome anodes as they wear, but I am not sure they are necessary.
So should I ...
1 Continue with the dome anodes - 1 each side
2 Dispense with the anodes as the tabs are stainless and are not electrically connected to anything else.
3 Attach them internally via their mount bolts to the stern gear bonding circuit. In their natural position they do not face the main anodes which are some 1.5m away.
The rest of my bonding circuit is now removed because I have changed all the seacocks to Forespar Marelon. I have fitted new strap links across the R&D couplings (2 on each) plus a shaft brush, because I do not want another pink propellor ! I have also replaced all the bonding circuit cables with 6mm2 wire with crimped and soldered lugs. All external fittings (props / rudders / shafts / P brackets) now measure barely above base meter resistance relative to each other.
I found last year that having shaft anodes as well led to a coating of what seemed to be a zinc like substance on top of the velox on the props. Whatever it was the barnacles loved it ! The main anodes are large oblong block anodes sited close to the propellors, between the bronze rudders & P Brackets. I don't wish to over anode again.
So should I ...
