Ian_Edwards
Hi, I'm making up some 3/8th inch BSP pipe fittings for the diesel fuel supply, engine, generator and heater. Speaking to the local mechanic he advised not to use PTFE tape, he'd had problems with bits of tape coming adrift and causing problems.
What should I use, bearing in mind that the fitting are mixture of SS and brass, and parallel and tapered threads?
Cheers Ian
Cheers Ian
