Total rubbish - shroud cleat - failed
Refueler
13 Sep 2008
Far away from hooray henrys
It didn't even get to having a flag halyard made to it ..
The circular fitting which fits round the shroud just pulled straight out of the plastic cleat.
I can see the design idea - but honestly ... unless someone has a magic suggestion - they will be consigned to the 'great idea - but unusable' locker !
Anyone actually fitted these and success ????
I needed similar to tidy-up dangly bits of flag string. I got these Pardon our interruption... And they are excellent. Simple but effective. The price was, I thought, a bit dear. BUT they do work, and are a doddle to fit. I assess as good value when I see how much simple plastic bits are in the marine world. Sorry: Usual strange link to eBay!?
Shroud Cleat for 4-6mm shrouds - pack of 2​
£19.96
Now that's better than the compression fitting rubbish I paid MORE for !!
Its crossing my mind whether I can use a U fastening round the rubbish I have - save wasting them >
£19.96
Are they 3D printed?
The photos make it appear so.
£19.96
I see seller says 3D printed ..... probably ASA filament ..
I use a rolling hitch on the shroud but first prep the area of the shroud with "rubber glue" and put an extra [third] locking turn on the hitch. lasted 20+ years on my last boat.
PLA filament is OK for light duty's as long as plenty infill used when printing ...
Many models for motor mounts specify ASA / PETG .. but I generally just use PLA with 100% infill and all is ok.
I'm going to try printing the various cleat designs I've found online ... see what happens.
By the way, is a 3D printer capable of machining a small diameter female thread?
Or will you have to get the tap & die set out?
Depends on the size and the printer, but usually post process or design in a hexagon hole that fits a suitable nut. If really keen you can get metal insets which are placed with heat.
