wrr
If you use a fluid like Loctite, it will act as a lubricant and you should apply less force as the reduction in opposing friction may lead to the bolts shearing.I have reassembled the engine and tightened the nut using a socket, Tee bar and mallet. Unfortunately it wasn't enough.
The nut undid and wrecked the key slot in the crankshaft. I've now regenerated the key recess in the shaft and it's ready for flywheel replacement. The flywheel has two large, otherwise unused, axial holes near the periphery and I will try to contrive something to engage with them. I agree the torque figure is high and I'm fearful of strpping the nut thread. I'll use Loctite.
Photos to follow.
