billyfish
I can charge mine straight off 12 volt or through a inverter but can't work out what's best
Me too, Torqueedo do sell a solar charging panel for a mere £550 or so, There must be a way to use a common garden £50 solar charger to do the same job surely?I'm thinking of one of these new fangled electric outboards will they charge off solar?
A Victron pv regulator has a 12v load output on itMe too, Torqueedo do sell a solar charging panel for a mere £550 or so, There must be a way to use a common garden £50 solar charger to do the same job surely?
My epropulsion does but it requires a 12 volt box of tricks to charge the battery.I'm thinking of one of these new fangled electric outboards will they charge off solar?
200 Watt hr solar = 200/12= 16 Amps but say 50% efficient so 8 Amps x 10 hours = 80 Amp hr x12 volts = 960 Watts .....sufficient for topping up 1 Kw Torqeedo battery?
You might get 50% efficiency in the UK if you keep moving the panel to follow the sun but for the average fixed panel it is nearer 25% or possibly less.200 Watt hr solar = 200/12= 16 Amps but say 50% efficient so 8 Amps x 10 hours = 80 Amp hr x12 volts = 960 Watts .....sufficient for topping up 1 Kw Torqeedo battery?
True. But who charges from empty to full? We have a dedicated 100w panel to connect to our E propulsion charger. It’s connected when the motor is not in use. We have not so far lacked the battery power to do whatever we’ve asked of it.You might get 50% efficiency in the UK if you keep moving the panel to follow the sun but for the average fixed panel it is nearer 25% or possibly less.
You need a big boat with space for lots of solar panels or frequent engine/shore power if you are using a Torqeedo regularly, or take the battery home with you to recharge after use
I didn’t quite understand why it would take 8 hrs on engine...
Ah OK - I hadn't reaslised they were using stupid cigarette lighter sockets. Its amazing that nobody had developed a better standard - ideally waterproof! So billyfish's original question - whilst there are losses of going via the inverter he might actually get a better experience - not overheating the socket, not wiggling loose etc.It's because if using the 12V charger the cigarette lighter type plug can only pass 10 Amps. At 12 Volts that's 120 Watts. To put in a 1 kWh takes 8 to 10 hours. The push in connector will still get hot and likely eventually melt its housing as is their wont at that sort of current.
Fair enough thats not unique to this forum and sadly even infects manufacturers or panels etc!For the people whose usage pattern is as you describe, then great, crack on. Free yourself from petrol on board forever. However, there is a widespread lack of understanding of electricity, power, consumption and their units in this forum.
Ah yeah I'm completely with you. A 10W solar panel is about the size of a piece of A4 paper though so not huge. 50W is probably the size of most "small" boat installations without an arch etc?My post on full recharge of a Torqeedo battery was just to point out the impracticability of using a 10 Watt solar panel to charge a 1 kWh battery. Even if only 10% of the charge has been used that will still be about 3 days of full sunshine with that panel in practice.
Your are right and I charge my Torqeedo like you say - it takes a long time but it will fully recharge on an 8+ hour motor. Or a top up takes an hour or two direct off batteries. My solar panel is 130W and over the past weeks in Scotland (without aligning to the sun) has given between 160 Wh and 480 Wh per day. That keeps the domestic battery more or less full without the engine but has no surplus except on a sunny day.It's because if using the 12V charger the cigarette lighter type plug can only pass 10 Amps. At 12 Volts that's 120 Watts. To put in a 1 kWh takes 8 to 10 hours. The push in connector will still get hot and likely eventually melt its housing as is their wont at that sort of current.
For the people whose usage pattern is as you describe, then great, crack on. Free yourself from petrol on board forever. However, there is a widespread lack of understanding of electricity, power, consumption and their units in this forum. My post on full recharge of a Torqeedo battery was just to point out the impracticability of using a 10 Watt solar panel to charge a 1 kWh battery. Even if only 10% of the charge has been used that will still be about 3 days of full sunshine with that panel in practice.
