Jonny A
I'm another vote for Toplac single-pack. Works a treat for me.
It's much softer.
Can you try sourcing another brand, like Jotun?
That's a bit alarming. How are you supposed to know what you are sanding?The idea was to only paint one side .. the bow / transom joins would be hidden by the change of form ...
Port side of boat is fine ... just needs a polish ...
To give idea of why two pack is outlawed for DIY use ...
My Pal has his B31 about 15m from another boat - that guy was sanding back the topsides ready to recoat .. wind was gentle .. fickle ... no signs of problem. But for 3 days after my Pal was coughing and reaching from the minute dust carried over from the sanded two-pack on guys boat.
Yes you will get similar from any dust and single pack paint - but the two pack is more injurious to health and was why it was restricted.
It depends on whether you can live with the softer finish.The more I think about this Two pack vs Single pack matter .. more I come to decision that the Single pack enamel is a better choice in the long run ... I can buy another pot later if needed easily ....
I chose two pack for my tender because it needs to withstand a lot of knocks and bumps.
For a yacht hull you might not need such a robust finish.
Do you keep the boat alongside? If so, I would avoid Toplac. Ok for a boat on a mooring though.
Maybe others have had better experience.
I would use Awlgrip Topcoat if you really know what you're doing. If you're competent try Awlcraft 2000 and if you're not pay someone to do it as there's nothing quite as frustrating as buggering up a refinish.
Except maybe paying someone else to bugger up your refinish?I would use Awlgrip Topcoat if you really know what you're doing. If you're competent try Awlcraft 2000 and if you're not pay someone to do it as there's nothing quite as frustrating as buggering up a refinish.
Car paint is what my XOD was painted with. Easy to spray, hard enough for a small race boat. Plus of course, as it doesn’t say ‘marine’ in the spec, it’s less than half the price.This 'soft' issue has me thinking ...
Long discussion with the yard and basically my local has no covered facility to do a serious paint job. Boss is not exactly keen to take it on ...
My discussions with another yard - 8hrs sail down the coast would unstepp mast and place boat inside after preparation for painting.
The question is - given the costs and amount of work .. boat is 38ft long - so its not big - but not small either ! Is it good to go with the soft Toplac .... or as a number of people - incl local yard guy - have suggested Car paint .. which is harder ?
I know a few people over the years that have sprayed with Car Paint ... never heard anything bad ... never heard anything to convince me to use.
Just throwing out thoughts .....
