bob26
Can you overdo the cathodic protection?
If so, what is the result?
I have mild steel bilge plates and rudder blade. In the past I have had 1kg doughnut anodes on the outside of each bilge plate and the same on one side of the rudder. I usually get quite a bit of activity on the bilge plate anodes (they last 2-3 years and produce a lot of white oxide-like coating over the zinc). The rudder blade anode has never needed replacing.
Last winter I found some quite deep corrosion pitting the bilge plates. I read somewhere that ideally a steel plate should be protected on both sides. So when fitting out for 2010 I added 1kg anodes to the insides of the bilge plates. So I have 5x1kg doughnuts down there with an additional clamp-on shaft anode to protect the bronze prop.
The result was that pretty quickly a lot of the antifouling on the steel parts seemed to shed (same International Cruiser a/f as always). This was especially true of the rudder where I got a bit more activity on the anode than usual. Naturally, I got weed and barnacle like I'd never had before on those parts which lost their a/f. I hope you can see from the pictures that the exposed steel rusted a bit as you would expect over a season but not excessively. The shedding seemed to continue throughout the year as some of the exposed steel did not get a chance to grow weed or barnacle.
Any idea what is going on here?
I'm on a half-tide mooring as far up Chichester Harbour as you can get...
