Tranona
You have to remember that your pattern of use is very different from most users who really don't have an issue with the standard Jabsco (which most are because boats are designed to take them). Even in my charter boat the original survived 7 years of that type of use and was still in use when I sold it after 14 years. The popularity of the marina or port hopping style of coastal cruising and the reluctance for many to discharge overboard encourages the use of shoreside facilities.You can almost always find better products but this is a good example of a product that is fit for purpose. If it was not then it would have been driven out of the market years ago!We had two with full sized bowls. This doesn't make the Jabsco pumping system any more reliable. In fact I believe the pitiful flushing system on Jabsco toilets works even less well on the larger bowl. Flush water doesn't even reach the front of the bowl unless you pump like a madman
