Elessar
I need to replace the loo pipe in my aft heads. Getting the pipe onto the seacock is going to be extremely difficult.
The seacock has a right angle on it and it disappears behind a bulkhead. You can get to the 2 jubilee clips but that's it, even the rest of the barb is out of sight.
The bulkhead itself is only about 4" from the transom, and there is clutter from steering gear. I can't get a hand in to pull the pipe onto the skin fitting.
This means the pipe is going to have to be pushed onto the skin fitting from under the loo floor. Do able only if the pipe slides on easily.
The white toilet pipe only slides on easily if soaked in boiling water. If I do this, by the time I thread it through its tortuous route it will be cold again.
I've been told butyl pipe is better as it doesn't allow smells out. But my question is, is butyl pipe soft and flexible, so that it will slide on easily, or is this a project I should delay until I'm out of the water (so I can remove the seacock if I need to)
