Kelpie
After lying around in pieces for years, I finally put my old outboard back together today. It hadn't run in over ten years and started on the second pull.
I think the impeller has given up though, because after a brief test run when I got back to the boat and let it idle out of gear for a couple of minutes, I noticed steam rather than water coming out of the telltale. It had been pumping water well to start with.
The manual doesn't explain how to change the impeller, and the only YouTube video I found suggests that the impeller is behind the prop. I think that must apply only to the version without gearshift, otherwise you'd have no cooling in neutral.
So... how do I access the impeller on the great shift version of this engine?
