TSB240
You might have been more shocked if you had checked the actual voltage at your navigation light. I have found a 3 volt or more drop where choc blocks have been fitted in line and gone rusty. Best dimmer you could fit!I was shocked and stunned to see I used some chocolate block in the anchor locker, surely the wettest and most inhospitable place on the boat. Though rusted and sad looking it had stuck to it's task for a quarter of a century - since the last time I had the pulpit off.
Corroded blocks are a good indication of capillary corrosion caused by moisture wicking in the cables.
Verdigris rules!
