Ravi
Hi,
I am about to set about laying a cable from the engine compartment to the a point just behind the mast. Does anyone have any tricks to minimise the amount of headlining that I need to remove?
The (solar) cable thru deck gland will be above the existing saloon central light fitting and near the mast support where I have a small (4" diameter) access hole.
Other than removing headlining, is there any clever way to trace how the existing cables lead back to the fuse panel? (I thought using the same route would simplify things.) At the minute I can't work out where they disappear to after the first few inches that I can see - especially, how they get past the strip of cabin wall headlining which seems glued to the hull.
When I work out where to run the cable, I was thinking of using something like a piece of bamboo to try and slide the cable under the headlining panels. ?????
I suspect that I am (typically) worrying and overcomplicating a simple job but I like to have a plan before I start and I am always reluctant to dismantle things which may not fit back together perfectly.
Any tips will be gratefully received.
Thanks,
Rav.
Thanks,
Rav.
