MagicalArmchair
So I am nearly done! After a liberal spraying with WD40 the bolt freed up completely and is now nice and loose and locks the outboard in the up position as its design to. I loosened the bowl and turned it around so that the drain plug was now very easily accessible so I could drain the carb when I was leaving it.
The final thing I need to do is seal the end of the starting string. I cut the knot off to take the cover off the engine as the knot was solid. Its now all a bit frayed and grim, normally I'd burn the end of the string, however, the string is stiff with oil... oil and a lighter seem like a bad idea... go for it with bucket of water on hand...?
