RichardS
N/A
A misfire at high revs could be an ignition problem. I doubt whether another new carb would solve it. Check that there are is no corrosion or deterioration in any of the ignition cables or components. Perhaps try spraying WD40 on the electrics to see if that makes a difference before you decide whether to replace components.I also have a Honda BF2D. 2 HP Outboard. Having a bit of a problem Perhaps someone has advice. Motor sat for several years. Decided to resurrect. Not surprisingly, the engine did not want to start. Most likely gas left in tank and carburetor. Decided best course would be to remove carb and attempt to clean. Did, unsuccessfully. Attempted to remove main jet and essentially ruined carb as it wouldn't budge. Purchased new honda carb after carefully determining part number. Installed new carb. Carefully drained tank and verified that tank filter was clear. Refueled with fresh gas. Changed spark plug with correct replacement.
After reassembly engine started on first pull with choke out. After choke in, the idle seemed somewhat rough but engine may not have been fully warmed up. The current issue is that the engine has a very distinct hesitation at higher RPMs. Engine is installed in a barrel of water so conditions are nearly as if on the lake. What is causing the hesitation or lag at higher RPMs? I am certain that gas flow is good. I have drained tank a couple of times through float bowl. I have considered buying another carb for $80 but why wouldn't new carb be good? I am certain that Honda put it on a jig to set it up properly. I did fiddle with the idle jet which only had about an 1/8 of an inch adjustment but that didn't help hesitation while reving engine.
What else could it be? Any suggestions would be appreciated. Oil level good. Not overfilled. I'm wondering about valve adjustment. Any thoughts on that. I originally bought motor used and never really gave it a good test. Perhaps it wasn't right early on? Could valves not closing properly cause higher RPM hesitation? What next anyone. Thanks for reading.
Richard
