[10753]
Any tips appreciated -like best departure time Gib, best route, any things to watch out for, basically any tips appreciated. Thanks
Weight a parachute anchor and let the deep counter current pull you through. That's what sailing ships used to do!
Not quite sure which way it works though.....
That's an amazing story......if true! There is a deep water outflow in to the Atlantic, because the heavy water flows out in to the deeper sea. The sun shining on the Med evaporates the water, leaving it more salty, which makes it heavier, which makes it sink and pour out in to the deep Atlantic, while lighter, less salty water flows in at the surface to replace it.
I believe that the same process occurs from the Black Sea to the Med, or is my geography faulty?
Whete did you read this fabulous tale Sybarite? I don't believe it, but it would be great if I'm wrong!
Didn't the subs use this during the war?
wasnt it the differing salinity levels they used
It is in Das Boot if anyone has the paperback. The water flows in to the Med at upper levels, to replace the heavy salt water which is gushing out in to the Atlantic, at very low levels.
I don't know what the actual depths are though,or have a chart handy, I think it's quite deep in the middle of the Strait though.
The Das Boot sub (correct me if my memory is going) tried to enter on the surface, was attacked, then successfully slinked out of the Med by going deep enough to enter the W -going stream.
Captnsensible's link suggests that NO U-boats made it back out of the Med, so the film varies from history on that point.
i have the dvd
